Toyota Sienna Forum - siennachat.com
September 06, 2010, 08:37:17 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
   Home   Help Login Register Store / Donations Forum Rules & Privacy Contact Us
Pages: [1] 2
  Print
Author Topic: How to get daytime running lights for free or how to get rid of DRL  (Read 1999 times)
kolkh
SiennaChat Supporter
Trade Count: (0)
Verified Member
Offline Offline
OS:
Windows Server 2003 Windows Server 2003
Browser:
Microsoft Internet Explorer 7.0 Microsoft Internet Explorer 7.0
« on: February 21, 2009, 06:56:55 PM »
This is a popular topic. Until its original author comes to this site and posts his diagram, I will try to put a wordy description based on info from varies sites.
For those [2-nd generation] Sienna models  that are not "supposed" to be equipped with day time running lights in the US, there is a simple way to install DRL option, free!
  • Find a fuse block in the engine compartment – look at picture “Engine compartment overview” in section 7.1 of the Manual.
  • Remove the fuse panel cover.
  • Look at the lower left hand corner of the fuse box, you will see an empty fuse socket to the left of fuse no 21. To locate fuse no. 21, look at picture in subsection “Fuses” of section 8 of the Manual.
  • Take a 30 amp fuse and plug it into the empty socket.
You have installed daytime running lights!
Those, who want deactivate DRL, should do the opposite – remove the pin from the socket that is located to the left of fuse no. 21
« Last Edit: February 21, 2009, 07:02:46 PM by kolkh » Logged
'06 Sienna CE 7 pass FWD
'07 Camry LE I4 5AT
jbarnett1971
Trade Count: (0)
Verified Member
Offline Offline
« Reply #1 on: February 23, 2009, 12:43:48 PM »
I have a 2008 LE with option package #1. I tried this out and it didn't work for me...did I do something wrong? Huh
Thanks for any help.
Josh
Logged
kolkh
Trade Count: (0)
Verified Member
Offline Offline
« Reply #2 on: February 23, 2009, 01:11:04 PM »
Was parking brake released?
Is fuse # 4 Ok?
Switch on high beams and check whether both lights are ON, if one is off, DRL will not work and you have to replace that bulb anyway…
Logged
'07 Camry LE I4 5AT
jbarnett1971
Trade Count: (0)
Verified Member
Offline Offline
« Reply #3 on: February 23, 2009, 02:52:22 PM »
 Roll Eyes Parking Brake? What is a parking brake?  Grin
Works wonderfully now...thanks
Josh
Logged
ricblake
Trade Count: (0)
Verified Member
Offline Offline
« Reply #4 on: February 23, 2009, 06:17:52 PM »
Aside from reducing the intensity level of the DRL, any other compelling reason to have the DRL resistor pack installed?
Logged
Rich
'91 Toyota Corolla Station Wagon
'07 Sienna LE 8-passenger
kolkh
Trade Count: (0)
Verified Member
Offline Offline
« Reply #5 on: February 23, 2009, 07:45:53 PM »
Before [re-]posting DRL “installation” instructions at this site, I had checked electrical diagrams and noted two items: a fuse or a pin or a wire, which needs to be added as per post #1, and a resistor pack. I cannot re-call that I’ve seen any discussion in any Sienna mod forum about the resistor pack.
I doubt this resistor pack can play any safety function in the circuit. Indeed, to create a DRL circuit, we connect two high beam bulbs in sequence. Each of them works under a half of their normal voltage. Thus, each consumes/releases a quarter of their normal power, they will be cool… The current will be twice lower than normal – wiring will be cool too.
Logged
'07 Camry LE I4 5AT
ricblake
Trade Count: (0)
Verified Member
Offline Offline
« Reply #6 on: February 24, 2009, 12:42:55 PM »
Hey kolkh,
I appreciate your response. I have asked about the resistor pack on the Siennaclub forum, and you are the first to ever respond. I've not seen one, but according to the schematic the pack contains only two resistors in parallel -- no other components. I believe it is only there to reduce the light intensity levels of the DRL's to meet federal standards introduced about 2004. I was wondering about any possible safety concerns in the circuit -- and you answered that question very well.
If anyone still wants info on the DRL Resistor Pack, the part number is 82690-45020 ($75-$100 new). If I can find one in the local bone-yard, I may install it just to bring the intensity level down a bit to match the factory-equipped Sienna's running around here.
Logged
Rich
steph280
Trade Count: (0)
Verified Member
Offline Offline
OS:
Windows XP Windows XP
Browser:
Firefox 3.0.13 Firefox 3.0.13
« Reply #7 on: August 14, 2009, 03:28:45 PM »
Sorry for the late arrival.  I was the original poster for this diagram on siennaclub.org.  Here it is again, along with what the jumper looks like.
Logged
robo5
Forum Moderator
Trade Count: (0)
Sr. Member
Offline Offline
OS:
Browser:
Microsoft Internet Explorer 6.0 Microsoft Internet Explorer 6.0
« Reply #8 on: August 14, 2009, 04:03:16 PM »
Welcome!! Glad you made it over here!
Does the "fuse" have a rating??
Or is this a "short" pin.
From what i remember from the "old" place was install a short pin OR fuse and away you go. You now have DRL.  A little more research into this and i "think" a fuse can be used.
Thanks steph280 to get this moving again.
ROB
Logged
2004 CE
AIR LIFT "1000"
OVERHEAD "DEALER" DVD
"HITCH CITY" 2" HITCH
Support "SIENNACHAT" HERE
steph280
Trade Count: (0)
Verified Member
Offline Offline
OS:
Browser:
« Reply #9 on: August 14, 2009, 04:25:28 PM »
It's a hard jumper.  But I've done it on 5 other Siennas using the spare 15amp (or was it 20 amp) fuse in the fuse box, they work fine as well.
Thanks for the welcome!
Logged
Deuce
Trade Count: (0)
Verified Member
Offline Offline
OS:
Browser:
Microsoft Internet Explorer 8.0 Microsoft Internet Explorer 8.0
« Reply #10 on: September 19, 2009, 08:03:45 AM »
Yep I used a spare fuse about 5 years ago on my '04 and it's worked ever since.
Logged
2004 LE-7 #4, bought 6-10-04.  Currently 87k miles.
(Formerly had 2000 CE, lease ended after 78k trouble free miles.)
94dlx
Sienna Fan
Trade Count: (0)
Verified Member
Offline Offline
Looking for my 2011!
OS:
Browser:
« Reply #11 on: September 21, 2009, 06:21:07 PM »
 Huh My apologies but I am confused Embarrassed. Do we need to use the resistor to prevent overheating of the circuits or does simply plugging in the "spare" fuse suffice? I want DRLs but I don't want to fry my wiring!
Logged
2004 CE
robo5
Forum Moderator
Trade Count: (0)
Sr. Member
Offline Offline
OS:
Browser:
« Reply #12 on: September 21, 2009, 06:48:58 PM »
Install a "fuse" into the spot and you are good to go. The "pic" showed a "short pin" which is like a jumper.
To be on the safe side 15 amp fuse is fine. Plug it in and enjoy Grin
Logged
2004 CE
AIR LIFT "1000"
Zero260
Trade Count: (0)
Verified Member
Offline Offline
OS:
Browser:
« Reply #13 on: September 22, 2009, 10:33:31 AM »
Sienna's with DRLs from the factory do indeed have a "resistor pack" - this is not the "jumper" in the fuse box (the one that can be replaced with any handy fuse), but another component that is mounted in the engine compartment near the passenger-side wheel well.  The resistor pack effectively adds 1 ohm resistance to the two high beams in series during DRL operation.  Like ricblake (see his post above), I assume that it's purpose is to lower the output of the high beams a bit further below 50%, presumably to meet some DRL regulation.  I have installed the jumper (but not the resistor pack), and I believe my DRLs are a bit brighter than other Siennas I see on the road - but I have not been able to do a side-by-side comparison.
That said, as kolkh pointed out there is no problem running without the resistor pack since current levels would already be half that of normal high beam operation.
Logged
Brad
2008 Sienna LE-8
siennami
Trade Count: (0)
Verified Member
Offline Offline
OS:
Browser:
« Reply #14 on: October 10, 2009, 07:33:08 PM »
I'm glad some people had questions about activating DRLs.  I did that shortly after I got my CE in '07.  I have noticed on some Siennas that have DRLs that their tailights seems to be affected, also.  Is that pretty typical with DRLs that are factory-activated, perhaps?  I've been wondering since they seem to be different from mine.  And, also, I was riding with my boss in her '09 XLE last week and I noticed that her dash lights were lit, so I wondered if that had anything to do with drls.
  Just wondering......
Logged
Pages: [1] 2
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SIENNACHAT.COM IS FUNDED BY DONATIONS siennachat.com/donate/
Valid XHTML 1.0! Valid CSS!
Page created in 0.052 seconds with 41 queries.
